Guest Anonymous Posted July 27, 2003 Report Share Posted July 27, 2003 So, I picked up this mic hoping to record band rehearsals. Tried using the powered mic in and the line and and was rewarded with distortion. I have not had the opportunity (nor will before the day comes to return it) for concert recording. The mic does not work for my primary purpose but, will it be useful for recording concerts? Or, will I get the same distortion problems? Should I just return this thing and check out other options? What about the ECM 907? Would this work for a band rehearsal situation? Any advice is gretly appreciated. Thanks! Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted July 28, 2003 Report Share Posted July 28, 2003 If your band is very loud, you probably need a battery box from Sound Professionals or suchlike to avoid distortion. I use the ECM907 microphone for recording classical orchestral music, and it works very well without a battery box, but then the volume is of course much lower than rock music. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 28, 2003 Report Share Posted July 28, 2003 The distortion could be caused by clipping, check your recording levels. If they are too high, hit pause while you are recording and lower the recording level until you don't get anymore clipping. Quote Link to comment Share on other sites More sharing options...
