Help! - MZR900 deleting discs
ChrisB
For the last week or so my MZR900 is deleting discs that I have played a million times before with no problem. I press play, and then after a couple of seconds I get a "BLANKDISC" message and the disc is totally deleted.
I am hoping that this is a known problem and someone can point me in the right direction. I haven't had chance to have a good search to see if this problem is here already so I hope someone can help.
Regards
Chris
Try a couple things. First, slide the write protect tab open to protect your remaining discs from erasure. See how your 900 responds to that. Second, if you have access to another MD player, check one of the erased discs on the other player to make sure it really is erased and the 900 isn't just pulling your leg.
If it really is deleting the discs, you can try popping out the battery before it writes the new TOC (so it doesn't record the information saying "Blank Disc") or invest in a recorder that will allow you to clone the TOC from an MD and rescue the music from your wiped discs--the music is still there, it's just that the disc has been given up for blank.
