Bazirker Posted August 7, 2003 Report Share Posted August 7, 2003 I know that there are devices capable of removing SCMS data from a digital audio stream, but are there any programs that can do it? For example, are there any plugins for winamp or foobar that would allow you to playback a CD and have a digital output on your computer not output SCMS data with the signal? Quote Link to comment Share on other sites More sharing options...
krhainos Posted August 7, 2003 Report Share Posted August 7, 2003 I don't believe there's any software that can do that -- although I'd feel safer if the SCMS stripper was a hardware pass-through type thing, for just $50 I'd go for one of the DIY kits listed under Hacking on the MD Community page. Quote Link to comment Share on other sites More sharing options...
highlandsun Posted August 9, 2003 Report Share Posted August 9, 2003 Check this driver out: http://spider.nstu.nsk.su/music/software/eng/vac.html I've used it a lot, it works very well. It takes audio from any set of inputs and routes it to any set of outputs. It installs itself as a virtual audio card. If you have digital audio inputs, it can take the input stream, extract just the audio signal and discard the S/PDIF control info (including SCMS) and route it back to the digital audio output, in realtime. It's extremely handy. Quote Link to comment Share on other sites More sharing options...
Bazirker Posted August 16, 2003 Author Report Share Posted August 16, 2003 Did you buy it? It's reeeeeeally expensive considering it's only software. That's almost half of what Nero 6 ran me, and Nero 6 came with like ten different programs. Is the demo version suitable? Quote Link to comment Share on other sites More sharing options...
