NetMD (MZ-S1) Optical recording and 0 seconds tracks
Guest Anonymous
Guest Anonymous
Hi to everyone,
I am recording from a Mac to my NetMD device using the Sonica USB audio card and an optical cable. I put the device in Sync-R and I'm using Audion to play mp3 with a 2 seconds of pause between each track so that the NetMD device can add track marks between two songs.
The weird thing is that is also add a 0 second long track between two tracks!
It's not a real problem, but it is really annoying!
Do you know why this happens and how can I deal with it?
Thanks!
Anidel
Guest Anonymous
By using Xmd I just noticed that that 0 second long track are, indeed,
0.40 or 0.80 seconds long.
This is weird...it means that there should be some noise right?
How can be noise on an optical digital cable?
Anidel
