Auto Pause - Sony JE480
Guest Anonymous
Guest Anonymous
I just got a Sony MDS-JE480 and the dealer avtivated an Auto pause feature.
How can I disable or turn off this feature - I cannot get it to stop pausing after each track.
I woudl appreciate any help
Thanks
  • 2 months later...
Guest Anonymous
I want to know how he set it to Auto Pause. The manual does not indicate that Auto Pause/Auto Space is available on a 480. It used to be available on almost all models and is a requirement for those using minidisc in a performance mode. You want to go to automatically go to Pause after the track finishes. Then you introduce your next song and press play.
The cheapest model available now with Auto Pause in the MDS JE640 at $345. unless there is a secret way of setting the MDS JE480, $190.
Most CD players don't offer the auto pause feature. I've seen it on a Denon model that was quite expensive. It is one of the reasons minidisc has been so popular among performers.
Perhaps the dealer knows a hack for decks similar to the N707 etc. hacks.
So maybe the JE480 how has JB980 functionality. In which case there should be a setting in the menu to turn Auto Pause On/Off, like the JB980.
If you press Menu with the unit stopped, enter the Setup menu and twiddle AMS a few times, you should come to an Auto Pause menu from where you should be able to turn it On/Off (if it works like the JB980).
Failing that, you should take the unit back to the dealer for them to reset, as the JE480 isn't supposed to have auto pause.
