Guest Anonymous Posted September 16, 2003 Report Share Posted September 16, 2003 Hi I'm trying to use the s/pdif-in option of my motherboard (GA-7VAXP rev1.1 & Bios F9) without success.. The bracket is connected to "spdif-in" on the motherboard, but when i try to record under Windows XP (i tried several programs), it doesn't record anything when i select spdif-in as source. I want to put minidisc recordings back into my pc (from my Sony deck's optical output to the motherboard's optical input). I saw on some newsgroup that a guy had the same problem, with exactly the same motherboard, but no one had given any solution. My onboard audio driver is up-to-date (Realtek's AC'97). The windows sound manager grayed out the s/pdif option so I can't change the volume which is in the middle. There is not much info on the s/pdif-in option of the motherboard in the manual or the internet. I figured the bracket changed to "input" when i connected it to spdif-in on the motherboard, am i right? otherwise, i would have to buy a 3rd party bracket? The output works perfectly All my drivers are up-to-date I'm using Windows XP SP1 AMD Athlon 2200+ ATI Radeon 9000 pro 128MB DDR 768MB DDR400 Thx for helping Quote Link to comment Share on other sites More sharing options...
