i3i2and0n Posted September 18, 2003 Report Share Posted September 18, 2003 :oops: hi, i was messing around "hacking" my n505 and i realized that i had changes the wrong key. so i went to reset it to factory settings. i tried to follow the instructions but my screen says "OFSET!" Does anyone have instructions on how to reset the 505 from scratch? Thanks Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 28, 2003 Report Share Posted September 28, 2003 I had the same problem with my N707. I reset it and then got the Ofset! srror. What I did was follow the instructions at http://www.minidisc.org/sony_mzr_reset.html to auto calibrate my unit. Do the CDMD Record, MD Playback and MD Record tests in the same order as the document says and you'll be fine. Quote Link to comment Share on other sites More sharing options...
