It's not recording!
Guest Anonymous
Guest Anonymous
Hey, my minidisc doens't record anymore... I've bought a new optical cable, I also tried to record using another cdplayer. I used another minidisc, tried to record another cd... nothing worked. so it has to be the minidisc player itself... but I definately don't know what's wrong, when I push 'rec' and then 'play' the display shows ''noSignal'' sad.gif
If you don't know the problem, should I go to a store and let it repair then?
thanks in advance.
Leon
