Utoc Error...
Guest Anonymous
Guest Anonymous
Hello,
I have an old Sharp recorder MD-MT 15 from 1999 that is a great sounding player and was a great recorder too...only problem is it won't record anymore :cry: It starts recording fine then when i turn the unit off it says Utoc Error!!! :x either way you put it it won't record at all...any solutions to this problem or do i have to take it to be repaired (would it be expensive?) would be nice to get it working...it was a very good recorder. I'm also thinking of getting the new Sharp r80 but does it have a remote with a screen on it? it should it cost $329.00
Thanks,
Bababooey
The dreaded UTOC error of the 1999 Sharp MD portables. It isn't worth fixing. Apparently even Sharp don't know the true cause of this. In a few weeks, you might find it won't even read discs, unfortunately.
Go for the R80 if you really like it - I'm really happy with my Sony MZ-N10.
