Guest Anonymous Posted September 24, 2003 Report Share Posted September 24, 2003 I bought my Minidisc yesterday and I've already messed it up. I did the hack to add the new features, and I thought it went fine until I put a MiniDisc into the unit and it said 'NO DISC'. It also makes a lot of noise. I've had a look around, and have the following questions: Does anyone have the default EEPROM values for this model? Should I reset the EEPROM and auto adjust the unit (as explained at http://www.minidisc.org/sony_mzr_reset.html)? Page 19 of the service manual lists a shit load of settings that have to be changed after a reset. Do all these need to be done? Can I auto adjust instead? Thanks for any help! Scott Quote Link to comment Share on other sites More sharing options...
syko Posted November 27, 2003 Report Share Posted November 27, 2003 When I had my N707 serviced at Sony, I previously had hacked it to add the extra features. I was able to revert back to my old settings by using the values listed in the hack guide http://www.minidisc.org/mzr700_to_mzr900.html. Go into service mode and: FCode 0 60 change the last two digits from FE (or FC) to A0 FCode 0 61 change the last two digits from 7B to 50. Those are the only two values you should have changed. Otherwise, you'll need to reset your MD player's EEPROM values. Quote Link to comment Share on other sites More sharing options...
