Help please
Olimar
I'm using OpenMG and an MZN1. Basically, I've lost the folder that had all my MP3's of a certain type.
Now these MP3s in OPenMG and I can view and play them - export them and all that. But, I want to put them back into their own folder on my desktop or whatever, but I cant get the move file option to work at all and I cant find the folder where openMG holds the mps you have put into a playlist.
Not that theres any presure, but if I dont sort this soon, I'm gonna take my frustration out on something or someone. It's driving me mad.
As I said, the right click move file, when in checkin check out, does not work for some reason, although I get a progress bar the file never actually ends up where I send it.
Thanks
