"Recording session failed"
Guest Anonymous
Guest Anonymous
I'm using an MZ-N1, imported.
Whether using Simple Burner or OpenMG the conversion process fails before the halfway point for any mp3 I've tried so far. I was first trying the daemons tools-simpleburner thing, then tried OpenMG 2.2 with the orignal mp3s. I get a "recording session failed" error in SB while still converting, and in OpenMG the conversion seems to just stall. The software doesnt freeze, just a stall in the conversion.
I've tried various mp3s, including ones that I successfully converted a few months ago. Since then, I reinstalled my OS (WinXPPro) and went NTFS, it this significant?
I'm about to try Sonic Stage but I think it's a lower level problem.
Guest Anonymous
Um... alright,
So I had the same problem in Sonic Stage, though it gave an error rather than stalling like OpenMG did.
Then I somehow caused the SonicStage Restore utility to activate. When that finished and closed, I decided to try SB again and low and behold it is working now.... So....
My main peeve now is the bloated obtuse shit of in install routine OpenMG has.
