Panasonic SJ-MR250 Help - Net MD Problems
Guest Anonymous
Guest Anonymous
Hello, i purchased the Panasonic SJ-MR250 back in April, 2003. Ever since then, i have had several problems using the Net MD feature on this unit. According to minidisco.com, I have to install BeatJam as well as SonicStage. I have done both as well as install the standard Net MD drivers. Sonic Stage only detects my MD player sometimes, and it always says that my disc is full when it tries to write songs to the MD. I'm positive i'm using blank MDs, even the unit says they're blank. Has anyone who owns the SJ-MR250 had the same problems? Also, can anyone give me advice as to how to fix these problems?
I've always bought Japanese units because the American series of MD recorders/players are just ugly. It's also an issue of quality. I paid around $300 for a fine piece of electronic equiptment, yet I can't get it to work with my computer, it's quite furstrating. Thanks for all your assistance with this matter! smile.gif
Guest Anonymous
I have this md model, I had several problems... because the software beat jam doesn't work in my windows (Brazilian version). He works, but a lot of times have mistake. The solution was to use the software Net MD Simple Burner, I installed him and it worked well! Try to see if it works for you. (to use this software you has to have OpenMG Jukebox installed in the computer, that software comes in the cd that came with the md player
