TOC Cloning with an MZR-70?
Akuma420
Hi all,
I am the one who posted below about my MZR-50 erasing 2 discs and my subsequent devastation. sad.gif
My offer in that thread still stands, if someone can recover these 2 discs, I would be willing to compensate them monetarily for their time and efforts.
However, I may be able to fix the problem myself, if a portable guru can help with this issue.
I found a webpage that explains how you can "trick" a deck into rebuilding a TOC for you so that you can play an accidentally erased disc. You do this by recording a full disc of silence and then using "test mode", you can copy the TOC from that disc onto the erased disc (by tricking the deck and swapping discs in test mode), allowing access to the content.
Here's my question: the website said this would work with Sony decks, but not with all portables. If I can get my working MZR-70 into test mode, does anyone know if this TOC cloning trick will work? And if not, can I rent about 3 hours of usage on someone's deck to get this resolved?
Please assist in anyway possible...these discs are irreplaceable!
