SonicStage & MZ N510
Guest Anonymous
Guest Anonymous
Sonic wount transfer the MP3s onto the MD
tried searching the internet for simmilar problem but no luck
anyways i also tried RealOne player and OpenMG and they both give me error simmilar to SonicStage's: "An error occured while converting the data"
i have all the latest drivers, updated software, the cables are properly connected, the music is not copyrighted nor checked out 3 times
the worst thing is it all worked perfectly before i had to reinstall windows
if you had this problem and know how to fix please reply or e-mail @ kuchervano@hotmail.com
thank you
ps: once i get Nero i will go and try the SimpleBurner trick :wink:
Guest Anonymous
to my great disappointment the SimpleBurner thing didnt work
when i tried to do it manually the convertion got to 50% on LP4 mode and then gave me an error: "Reading from Audio CD failed. The recording session has stopped"
i am really stumped on this
  • 4 weeks later...
When you reinstalled windows, was it a clean install? (ie: fdisk, format, install, reload programs from installer discs/files?) Or did you install windows over windows, to try to fix some flakey driver?
If it was clean, then I'm really not sure what's going on.
If it wasn't which is what I suspect, then you've probably got
something corrupted, and it needs to be wiped out compeletely.
It's probably part of sony's software and just needs to be cleaned up
and reinstalled.
On the flip side, can you record from a physical cd to md via sonic or simple? have you tried encoding a small .wav file?
The hardest part will likely be figuring out where the problem is, so you can figure out how to attack it.
good luck
-Jeff
