PDubs Posted October 11, 2003 Report Share Posted October 11, 2003 I'm a noob, so please bear with me...I have a Sony MD player (MZ-R500) and putting songs on there is no problem. However, it's done through the analog signal so recording speed is 1x and it records the songs as one LONG track. Is there a way to make it such that: 1) I can record at a better speed (either 2x or 4x)? 2) I can record the playlist as played. Meaning, if I have 30 songs, then 30 tracks will be recorded and not just one huge track? Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted October 12, 2003 Report Share Posted October 12, 2003 No to both of those I'm afraid. The R500 being low-end and old generation recorder is restricted to the basics in it's recording abilities. For faster recording you could consider a newer NetMD recorder, or CD/MD deck/bookshelf system. For proper track marking Sharp units sync much better than Sonys in analogue, although digital (optical) recording would do it if you have the right equipment (as I'm sure you're aware). Quote Link to comment Share on other sites More sharing options...
