help!!!!! md mz-n910 service mode !
Guest Anonymous
  • 4 months later...
But why? The MZ-N910 is one of the best MD players Sony has produced and you still want to muck around with it?? Crazy unless you are trying to fix a problem. Otherwise, I can't help you because I don't know how to get into it.
Go to the service manuals page and open the one for MZ-N10. I used it to investigate a problem I have with my N910. The sequence is the same for both units I did the self test and found errors in the unit then later I followed the reset procedure and cleaned the errors. I will advise you no to change any parameters just use it in self test mode to see if there are any errors. I hope this help.
