poor quality in transferring mp3 to MD. PLEASE HELP ME
Guest Anonymous
Guest Anonymous
:x Hi I'm very angry, cause I cannot solve a problem which afflicts my mini disc. when I (through USB) transfer (or "check out") mp3 to my sony netMD nz510 using either sonic stage or openMG some records really play shitty. but not just low quality, you really can't listen to them, cause the sound is really disturbed. Some other records play very good. I'm of course referring just to mp3s cause songs I check out from CD's play excellently. Just a couple of days ago, I discovered that even if I play those songs, which result to be unhearable in my MD,on my PC in Sonic stage or OpenMG , they result to be unhearable too. Using for example creative jukebox I have no problems playing them but if I play them with the sony softwares they're played really in bad quality and this happens also listening to them on my MD. On the other side songs which don't give me problems being played on SS , don't give me problems in being played on MD. I thought it was a minidisc problem, but now after discovering they play bad also through SS on my PC I think that maybe it's a computer or software problem. I hope to have explained the problem and that somebody will be able to help me. Can anybody help me?
