kapkorn Posted November 9, 2003 Report Share Posted November 9, 2003 I am gettin one of thse from a friend for cheap. I want to record live concerts with it, what mic should i get for it? I dont want to spend a ton though. Quote Link to comment Share on other sites More sharing options...
kapkorn Posted November 11, 2003 Author Report Share Posted November 11, 2003 is this decent? batt powered.. http://www.audio-technica.com/guide/line/a...atr/ATR35s.html Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 28, 2003 Report Share Posted December 28, 2003 That AT mic is mono and only goes down to 50 Hz, so you'll miss some bass. There are lots of affordable mics that go from 20-20000 Hz and are stereo mics. Look at www.soundprofessionals.com for good, well-explained choices. There's also an ultra-cheap one-point stereo mic that shows up on Ebay--search Audigy in titles and descriptions. And since you only have a line-in input, you're going to need a battery box with any mic you buy. Quote Link to comment Share on other sites More sharing options...
