Idiot Newbie
defiant
Well folks, I am sure you all love questions from idiot newbies. So here goes a few. Any help and pointers would be appreciated. Flames are fine too.
I just bought an MZ NF610 and a microphone, with the intention of recording various bits and pieces. I am sure you have figured the problem out already. I kinda wanted to be able to use the sound for other than listening to on my minidisc recorder, I wanted to be able to put it on cds, edit it, etc etc.
As far as I can tell, I should either return the thing, or buy the right sound card, and then I can put it on my computer etc. Why is there not an easy way to do it? Why does sony not provide for reverse downloading?
I will admit I didn't do enough research. I saw the good folks as NPR use the things, so I figured they must be easy to use and easy to access the sound.
Should I just go buy a tape player or what?
