records well, but softly.
defiant
I bought a MZ-NF610 and a Sony ECM MS907 mic to go with it. The combo records pretty well, but it seems kind of soft, as in, not loud. The recording level is on auto, and sterio. I listen to it on headphones and I have to crank it all the way up to get any kind of a listen out of it. The subject was no more than 20 feet away, and loud, so I would think it would record louder. Should I just go manual recording level?
The actual recording quality is nice, just overall it seems that it should be listenable at say, 15, instead of 30 volume level.
I was going to get rid of the thing, but now that I got the line out to record onto my computer, I am going to keep it. It is a pretty neat little gadget.
thanks
Guest Anonymous
Yeah,
i also have a MZNF610. I purchased an Audio Technica mic powered by a AA battery, and you have to crank up the volume to hear anything.
THe reason for this is because our NF610s don't have microphone inputs, which are basically line-in's with a preamp that amplifies the volume into the MD recorder. You could try getting a 9V-powered microphone, which provides more power for line-ins, but if you want to increase the volume then you could try amplifying it by computer.
Cheers
