Kuoi Posted November 26, 2003 Report Share Posted November 26, 2003 I'm dissapointed. I've bought a battery box and still have some problems ... or can I say ... MORE problems than before I've tried to record a gig last weekend , but had to low signal. Somebody pointed me out , that it's kind of normal with a battery box , so...I've tested it today to be sure . IT'S MORE distorted than WITHOUT the battery module. I don't dare to buy a SP-CMC-2 microphone now, because my friend tested it too , with his mic. , and had the same problem. My equipment: SHARP MD-MT99 minidisc recorder The Sound Professionals SP-SPSB-3 battery module Vivanco EM216 Microphone My microphone specifications , for what it's worth: Frequency response 20Hz–20kHz impedance 600 ohm. I didn't used the 'pre-amp' of this microphone - because I don't want to destroy the BB - when I've tested it , so if this can be used , and IF this should fix the problem: How can I connect it to the batterybox ? 1 ) Minidisc > Batterybox > Pre-amp > Microphone or 2 ) Minidisc > Pre-amp > Batterybox > Microphone And I've 'updated' the pre-amp to a 9 Volt pre-amp instead of the original 1,5 Volt Should 1,5 Volt be enough - because it's a bit smaller to wear then - If this can fix my problem that is ?? If I should know that it will work fine with some other microphone (cardoid) , I'll buy it IMMEDIATLY , but who can asure me it will ? WHO CAN HELP ME OUT ?? BTW : Sorry for the capitals. Greets , and many thanks in advance , Kuoi Quote Link to comment Share on other sites More sharing options...
