Guest Anonymous Posted December 10, 2003 Report Share Posted December 10, 2003 Hi, I've been trying to record live shows of my band and I need to have the minidisc close while the mic is positioned about 15 feet away. my question is are there extension cables for this? and will I lose sound quality by doing this? thanks Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted December 12, 2003 Report Share Posted December 12, 2003 You just need a standard stereo extension lead with the correct jacks (probably female and male at either end). Any decent audio or musical instrument shop be able to sell you one or knock you one up to that length. For the best quality you should have gold-plated connectors and oxygen free copper cable. There will be a slight theoretical deterioration in the signal, but it will be negligable at that distance, so don't worry. Quote Link to comment Share on other sites More sharing options...
