Anyone have trouble launching SimpleBurner?
taterwa
I've installed Simple Burner on a couple different systems, both running WindowsXP, and *neither* one will run the program...it instantly crashes as soon as I launch it. So currently, the only machine I've got that will run Simple Burner is an old junky eMachines box.
Does anybody else have this problem with Simple Burner? I emailed Sony and got a response that had nothing to do with Simple Burner...it only mentioned Sonic Stage.
Any help would be greatly appreciated.
I think i've got exactly the same problem, thing just crashes when i start the program.
gives and error starting...
exception information
code: 0xc0000005 flags: 0x00000000
record: 0x000000....0 Address: 0x000000...040bldf
then loads of other stuff. dunno why. do you need to have sonic stage installed to run the program or something?
