mp3gain?
Guest Anonymous
Guest Anonymous
sup
When I "gaining track" or whatever its called.. some music files gets red and is noted with a Y under clipping. whats that all about? is that something to think about or what?
Thx
/TimS
  • 3 weeks later...
Guest Anonymous
Yes. Clipping is sonething that happens which damages the sound quality when you raise the volume too high.
The solution to this problem is to choose a lower volume to MP3gain all your MP3's to. Otherwise, you can set these MP3's aside and just MP3gain them lower.
The good thing is, the damage is not permanent, since its just an effect of some values in the file being too high for an MP3 decoder to read the signal properly. Just make sure to lower the volume of those clipping MP3's and they'll be fine.
