check-in fails when transfering mic recording-help
mrtn
check-in fails when transferring mic recording from MD to SonicStage music drive. Any ideas on how to make a live recording with mz-n10 md (with mic). Then transfer it to music drive with sonicstage.
I am getting the error
Detecting errors while transferring
(check in failed
"file name")
I want to record live music with the mic and be able to load onto computer and cut into tracks and burn to cd.
using sony mz-n10, sony ecm-719 mic, sonicstage software- recording is fine. I can listen to it on the md player, it shows up on the sonicstage info but get errors when i try to transfer to music drive(hard drive) help!
Checkin of recorded songs is not supported by NetMD but by the new upcoming Hi-MD. With normal NetMD you need to re-record to the PC with an audio connection.
My app win nmd might help on this, too. There are not that convenient freeware alternatives like audiacity. (if I remember it correctly)
