recording my MD to a CD-R via the optical link
udolfo
It depends if this cd recorder of yours has an optical in.
If so then you can use the 530 to pipe it into the cd recorder via the optical cable, (probably minus the track marks).
If not then your only hope is indeed via analog.
As for the quality loss, depends on the quality of the cables being used.
If you used those cheap "dollar-store" specials then yes considerable loss and interference will occur.
Also be sure not to have any fluorescent, xeon or hallogen lights turned on while recording,
as well as computers and other such devices operating nearby should be off.
