Need Power Input Plug - where to find one?
I just purchased an FM modulator to play my R900 in the car thru the radio. ebay $20. It plugs into the cigarette lighter and powers the MD BUT... of the 5 adaptor plugs which come with the modulator, NONE is small enough to fit the Sony MD power input connector.
Radio Shack shrugs their sholders
WalWart 3v cemetary has an unlisted address
Where are lil' bitty power plugs available?
Sony CD Walkman use the bigger size.
Help, please. I'm tired of listening to Michael Savage and need some guitar music.
That's odd, I have an adaptaplug from Radio Shack that works with my MZN10. It's a type 'B' adaptaplug. Who makes the FM Modulator you're using? I have one ("irock") that runs on two AAA cells, it's a bit weak on runtime. The only advantage is that it's portable, I've used it indoors when visiting people who have a radio but no stereo system with aux inputs.
  Quote
That's odd, I have an adaptaplug from Radio Shack...
Good to know...I'll light a fire under them.
  Quote
...Who makes the FM Modulator you're using?
I chose the SoundFeeder SF-100 spcifically because of the car-power feature. I go through $20-30 small batteries / month as it is. If if wasn't for CostCo's Kirkland batteries I would be in bad shape. (badder)
Thanks
