Guest Anonymous Posted January 27, 2004 Report Share Posted January 27, 2004 What is the highest quality of MP3/wma that can be converted to LP4 with little loss of quality - im happy with LP2, but if i could get away with LP4, then that might be good! Cheers Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 27, 2004 Report Share Posted January 27, 2004 I don't quite understand the question... LP4 is so bad, that I don't think it will make a big difference whether you're converting a 128kbps MP3 or a 320kbps MP3 to it. Generally, I would just advise against converting from anything under 128kbps, because a double-whammy of heavy compression like that will definitely sound bad. Quote Link to comment Share on other sites More sharing options...
