can any one help me to "check in" in one MZ-707 ty
Guest Anonymous
Guest Anonymous
i've recorded some conferences in my MD, input mic, but when i want to check in to my PC, it appears a mark that means ZERO times to check in or out, how can i change this mark or what can i do to check in those recordings, i really need them, they're from the job, please help me!!!!
Guest Anonymous
Sorry, you cannot check-in a recording made on your MD.
Upload is not possible from classic equipment.
Check-in means upload, as the original is not on the harddisk.
You have to go the old route - through the soundcard.
For future recordings, Hi-MD would be a solution, as these recorders would allow the upload of analog recordings.
But that means, new equipment...
Hope, this helps
Jadeclaw.
