RealOne with Sharp NetMD
Guest Anonymous
Guest Anonymous
I've been using Real Play 10 with my Sharp IM-DR400 and it works fine. I normally wouldn't have Real on my computer but it gets around the check in/check out nonsence and gives you the option to delete omg files after transfer, so conserving hard drive space.
If anyone has worries about using Real Rlayer with regards to spyware, I would advise that you go thru the Preferences and untick anything that "phones home" including the Real Message Center and, if you have a firewall like Zone Alarm, do not allow the program internet access once you have installed the plug-in.
RobBeer
