DWest Posted February 3, 2004 Report Share Posted February 3, 2004 Got my first MD player a Sony MZ-N510 to record telephone interviews (with permission). My set up is through a Radio Shack device that goes from the phone to Line In (optical) on the MD. When I record and playback at maximum volume it is barely audible. I manually increased the input volume to max. Am I doing something wrong? Is there better way to do it? Better unit or better brand? BTW I used the same phone set up with a basic tape recorder and the volume was decent. Thanks in advance, David Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 10, 2004 Report Share Posted February 10, 2004 Line in expects an input with some power. If your phone gizmo works like a microphone, with little output power, then it may not be enough to drive line in. On the tape recorder, are you putting it into a mic-in jack? That amplifies the signal, which line-in doesn't. Given the price of mic preamps, you might be better off finding a used MD player: Sony MD-7xx, MD-9xx and MD-N** all have mic jacks, or look for a Sharp MT-190 (not 180/170). Archos makes a mic+preamp for its Jukebox recorder that I've seen advertised for about $50--you'd have to do some investigating, but if the preamp is separate maybe you could plug your mic into that to get some gain. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 11, 2004 Report Share Posted February 11, 2004 Quote Got my first MD player a Sony MZ-N510 to record telephone interviews (with permission). Well, if you're handy with a soldering iron, or know someone who is, just build a preamp: http://www.ee.washington.edu/circuit_archi...cuits/Micro.GIF http://xoomer.virgilio.it/fladelle/Page49.htm The second one offers better quality. Parts should be available at any Radio Shack outlet... Quote Link to comment Share on other sites More sharing options...
