sharp toc error
Guest Anonymous
Guest Anonymous
I have read many posts extolling the virtues of Sharp units over Sony for recording live music.
I have been using a Sharp MD-MT15 for live recording using a small mike made from Radio Shack parts. Results were just great. No complaints.
However one day the unit started displaying a TOC error and refused to record :shock: . Playback still works fine.
It seems this is not uncommon.
Can this be fixed ? Is my unit junk ? I feel like avoiding all Sharp units but I have had trouble finding a similar Sony or other unit. Many dont have a Mic input.
Any suggestions ?
Any words of wisdom ?
Anyone know a fix ?
Thanks
This is perhaps the one fly in the ointment of Sharp MD superiorty. The dreaded Sharp TOC error was a common problem with that generation (and earlier) of Sharps.
Apparently there's nothing you can do about it once that happens, but I think you could still use it as a player. If you do, I would write-protect the disks you use.
According to users Sharp seems to have fixed the problem after about the MT80 - I hope so, my MT80's is still going strong. You will certainly be fine with the current crop of Sharps.
