Non NetMD PC to MD recording Best Program to use??
BobLabla
Guest Anonymous
I don't know about Alcohol 120%, but all you need for the best-possible digital PClink transfer is a good, low-resource MP3 player, which you can make sure isn't resampling the music or adding any EQ/DSP effects.
I recommend Winamp 2.X or Winamp 5.X.
I'm using Winamp 5 for this, output is optical from a Terratec soundcard.
Settings - Winamp: Volume 100%, Balance center, all effects off - including EQ and Crossfading.
Settings - Mixer: All sources except Wave off, EQ off, all effects off, including 3D-sound and Source positioning.
And under SP/DIF copyprotection off...
Finally Wave - level full open.
The mixer settings are identical for CM8738-based soundcards (Nightingale et al)...
If you don't have a decent soundcard, one of these Xitel USB-thingies are worth a look.
Hope that helps.
