Having trouble with my AIWA AM-NX9
Guest Anonymous
Guest Anonymous
Hello this problem just occured recently , i had trouble with my computer and then it got repaired, a few weeks after i wanted to change some songs in my Minidisk. i have sonicstage 1.5.5 , i plug the minidisk player to my computer via USB, and i plug the electricity thing to my md. But for some reason it doesnt DETECT my md. it says "device is not connected" also when i plug in the usb theres this window that pop up that says "Found new hardware , Net MD." i click on install automaticly (i think its that) and it says blabla nothing found to install. im really looking forward to fix this annoying problem =(
is there any other way to put songs in my md? an easy way? :)thanks!!
Hi, welcome to the forums. :sleep:
Anyway, this is a note to you: please do not triple post topics in the future, as this is heavily frowned upon. As for your problem, you need to install the software/drivers before you plug the unit in, as it's like that with pretty much any USB device [plug and play is overrated]. Try installing the software/drivers first and then plug it in and report back; if that doesn't work I'm sure our brilliant resident guru and moderator of this forum, iceeedtea, will assist you.
