problems still persist with song transfer
woda123
i have attempted to run objsir.exe but it will not connect to the internet eventhough i am connected. furthermore i did download sonicstage and attempted to transfer songs but the the songs do not transfer, i get an error message stating that "errors occured while tranferring 'song name'". is there anything else i can do?
i was at the same place you are, try this out:
SUMMARY:
How to restore the backup information when unable to connect to the Internet to use the system information restore tool in the Microsoft® Windows® XP operating system.
RESOLUTION:
Follow this procedure to restore the backup information manually.
IMPORTANT: The operating system must be configured to show hidden files before beginning this procedure.
Close the OpenMGTM Jukebox or SonicStageTM software if it is open.
Click the Start button and then click My Computer.
In the My Computer window, double-click Local Disk (C:).
In the Local Disk (C:) window, double-click the Program Files folder.
In the Program Files window, double-click the Common Files folder.
In the Common Files window, double-click the Sony Shared folder.
In the Sony Shared window, double-click the OpenMG folder.
In the OpenMG window, double-click the Restorable folder.
In the Restorable window, click to select the ICV.DAT file.
On the keyboard, press and hold the CTRL key.
NOTE: Holding down the CTRL key while a file is selected will allow for multiple files to be selected.
In the Restorable window, click to select the MACLIST.DAT file.
On the Edit menu, click Copy.
Under the menu bar, click the Back arrow.
In the OpenMG window, on the Edit menu, click Paste.
NOTE: If prompted to replace files, click the Yes button.
hopefully it will work for you, i didn't have the directory that it refers to so my installation must have been botched.
good luck!
i tried everything you trold me. enabling hidden files making sure the program is not running. unfortunately when i get to the open mg window i do not have a restoreable folder. if you have any other ideas i am willing to listen. thank you for your help
I did not have the restorable folder either. I tried another uninstall-reinstall with my Openmg cd and all the patches and upgrades from the sony site but now none of the programs will run. After clicking their icon to open, the splash logo for whichever program (opnemg, sonic stage, simple burner) pops up for a split second then dissapears and I'm left with an error message saying it encountered problems and had to close.
Has anyone solved or gotten around this issue of not being able to run sonys software?
