stevo Posted March 4, 2004 Report Share Posted March 4, 2004 Hi. If i record music onto an MD with OpenMg - then i decide to delete a track or two - is there a way to do this on the unit itself? - its the N505, or do i have to use the pc i used to record in the first place to delete tracks? Does this mean that all my MD's that i have recorded with this PC will be permanent when this PC gets replaced? i.e. - i will never be able to delete tracks/entire MD's when this PC gets replaced? Quote Link to comment Share on other sites More sharing options...
onlykaria Posted March 4, 2004 Report Share Posted March 4, 2004 if upload the misuc via line in or simple burner the tracks are unprotected and you can MENU>>EDIT>>T:Ers otherwise if you use openMG, Sonic Stage, RealOne or RealPlayer 10, you need the computer... ps. i havent tried but i am sure that if you unstall openMG on another computer you should be albe to delete tracks from other computer as well Quote Link to comment Share on other sites More sharing options...
