newminidiskfreak Posted March 12, 2004 Report Share Posted March 12, 2004 hi, i'm kinda new to the whole minidisk thing, but it rocks! i've been using a sony mz-r900 that i bought second hand in pristine condition a few months ago, i'm pretty sure no one's messed around with the service mode thing. recently, i dropped the player to the floor, in the street. the battery cover got kinda buckled, but the player was working fine. next day, the sound is coming out a bit weird, so i check everythings ok, and it seems that the problem is a mechanical one. the headphone jack feels different, a little more loose perhaps, and, whilst i still get sound in both speakers, it is alot weaker, and occasionaly cuts in back to 100% sound. is there any way i can get this fixed? plz help. (sorry for the incredibly long message...) Quote Link to comment Share on other sites More sharing options...
Christopher Posted March 17, 2004 Report Share Posted March 17, 2004 Sounds like you have two options: Get it repaired by Sony, or buy the actual part from Sony and try to install it yourself. Quote Link to comment Share on other sites More sharing options...
newminidiskfreak Posted March 17, 2004 Author Report Share Posted March 17, 2004 cheers mate, but i managed to fix it over the weekend. i ended up cracking the case open, the insides look cool, but it had nothing to do with the insides,,, if anyone has the same problem, try using a saftey pin; make a small hook, at the end of the pin, then compare the insides of the jack(by looking in with a torch) with the mic and line in jack sockets, if a couple of connectors are missing from the side that are in the other two, try 'hooking' them out with your pin, it worked for me, and now i'm happy as larry.... or floyd,,,, or jerry, maybe even ethel! cheers kurisu for the advice anyway. :cool: Quote Link to comment Share on other sites More sharing options...
