MD to Macintosh question
diloretta
OK, I'm new to mds so please bear with me. I bought a Sharp 722 because I need to record some sounds for a movie. My Macintosh says that I can connect my recorder to the computer using a 3.5mm 1/8 miniplug. The computer has a miniplug outlet. The plug that came with the 722 is a male to female and it seems like I really need a male to male plug. Is that what I really need or do I need an interface between the 722 and the mac?
Guest NRen2k5
Well, Sony Music is completely anal about Digital Rights Management, so they don't allow any players to be made that can transfer digitally to PC. So, there is no interface that you can use.
But YES, using an analog miniplug will work. And yes, you do need a male-to-male.
