mz-e25 ...experts come and point out to me!!!
indianripper
i also own a n510 and plan to use the e250 for joging
plus i read some description it only runs for 2 hours on ni-cd!!!
is this true :sad: ...
and when i press the stop button on the remote....
the player shuts down after 3 second ..
.but when i press the play button on the remote........
it comes on but does not play unless i press the play
button on the unit itself.....
is this normal.?...remote = RM-MZ35
please guys ..clarify......
:wacky:
guys ...i just bought a second hand mz-e250.....
Which one did you buy, a MZ-E25 (as stated in the title) or a MZ-E250 (never heard of that one).
also own a n510 and plan to use the e250 for joging is this recomended
Shouldn't be a problem unless you're planning to do other things with it then listening to music.
plus i read some description it only runs for 2 hours on ni-cd!!! is this tru
Unfortunately yes, mine never gave me more them 3 hours of playback time. Things are a little better when you use a gumstick battery.
is this normal.?.
Mine never did that. Sounds to me that there's something wrong with the remote.
