question/help/confused!!
r0xychIc
Did you install the drivers and the software before you hooked the unit up to the computer? Also, if you don't have success, you may want to try uninstalling and then reinstalling properly.
How to properly uninstall NetMD:
1. Uninstall all OpenMG related software via the Add/Remove Programs control panel and reboot as necessary. This means, OpenMG 2.2, related 'Limited Patches' and the 'Secure Module', SonicStage, Simple Burner, and RealOne.
2. If you run Windows XP, proceed to delete directories within 'C:Program FilesAll UsersApplication DataSony Corporation' and 'C:Program FilesSony' relating to OpenMG.
3. Start -> Run -> regedit. The 'Registry Editor' utility should appear on your screen. Delete the references to OpenMG located under 'HKEY_CURRENT_USERSoftwareSony Corporation' and 'HKEY_LOCAL_MACHINESoftwareSony Corporation' by right-clicking on the entries.
After that, you'd install the software/drivers again and then plug in the unit.
p.s. Welcome to the forums. :happy:
