classicalnut Posted March 17, 2004 Report Share Posted March 17, 2004 Does a mic pre-amp actually work better than the mic in on a recorder? I record mainly classical music. I have seen many adds for these and was wondering if they do indeed make a difference and which one does everyone suggest using. Thanks, Classicalnut Quote Link to comment Share on other sites More sharing options...
devo_ji Posted May 5, 2004 Report Share Posted May 5, 2004 I believe, from what I have read, that the louder the music you want to record the better off you are using the line-in. This bypasses the mic-pre in the unit which I guess suffers from having to be so small to fit in the tiny MD case. Also the mic-input is more prone to distortion. Given that many classical performances can get pretty loud I would pay a little extra for a pre-amp. Now the question becomes which is the best low cost pre-amp for the money? Quote Link to comment Share on other sites More sharing options...
A440 Posted May 5, 2004 Report Share Posted May 5, 2004 The quality of the mic is paramount. If you have good mics and place them well you can get a pretty impressive recording through mic in, assuming the music is not so loud it overloads. If you then want to make a modest additional improvement, you could get a preamp, because mic-in does add a small amount of noise. The quieter the music you're recording, the more a small amount of noise matters. A preamp does not always provide extra headroom with loud music--sometimes it provides less. You have to get a preamp with a switch that allows different amounts of gain, so that loud music would use minimal gain and quiet sounds would get more. It's a toggle, not a volume control, so you'd have to decide in advance which level to use. I have a preamp with just an on-off switch. It did well when I recorded a quiet concert--voice, guitar, percussion. But when I recently attempted to record a loud show with it the result was disastrous, distorted on every loud note. When I saw that the record level was peaking, I turned down the manual level control and ended up with a quieter recording of the same distortion. I got in touch with the pre-amp manufacturer and was told that this particular pre-amp, without variable gain, was only for quieter sounds, and a battery box is better for loud music. Many places sell more flexible preamps with different levels of gain, like Sound Professionals. And I see one now and then on Ebay for $49.99 by Crown Audio that also has a gain switch--I would love to know how it works if anyone has tried one. If you're recording a string quartet, you'd want to add gain; if you're recording a Mahler symphony, maybe not. The real question is, how dissatisfied are you with your current recordings? And how good are your mics? Quote Link to comment Share on other sites More sharing options...
