SHARP MT-280 ???
gilli_
Am considering purchasing a SHARP MT-280 for making field recordings.
Any comments? It seems kinda inexpensive so I'm a little concerned it might not be up to the task?
gilli_@o2.ie
Mod edit: don't double post in the future. Your posts have been merged into one.
[begin merge of post]
Have spotted what seems to be a great deal on a SHARP MT-280 but when I tried to check out the specs/reviews on the web I couldn't find them anywhere..
I want to use my minidisc for making field recordings so my requirements are quite simple:
(i) mic-in (not requiring seperate power)
(ii) change recording level on the fly
(iii) reasonable battery life when recording in SP would be nice & taking regular AA batteries inside the unit would be nice too since I won't always have access to a power outlet for recharging
Anyone out there have one of these or perhaps have any info for me???
[/merge of post]
Not sure if the MT280 has a mic in, but I believe it does. I have the MT290 which is in the MT270/280/290 series. It's a good budget model and will provide all your stated needs. (10 hours recording in SP mode).
If you could get hold of the IM-DR420 it's only a little more expensive and has the new Auvi digital amp which gives a clearer sound (arguably) and NetMD as well as the MT290's facilities.
Here's some specs:
MD-MT270/290
IM-DR420
Cheers
