MDMX4 multi-track recording problems. please help!!!!!!
AgalsoffMD
So here's the deal. I have a MDMX4 machine but I can only record on two of the four trackes per channel. What is going on? I realize that normal MDs only allow two channels so I bought two different types of data disc to try and remedy my problem. I have a MMD140A data disc that only shows up 2 tracks ...... and, a MDD140 disc that does the same. Why can't I get 4 tracks? Does anyone know? And if not, do you have any suggestions as to where I can go for help?
thanks!
I have two types of data disk and neither of them will show up as 4 tracks when I pop them into the machine. One of them says it's a Sony MMD140A and the other one is a HHB MDD140. What other reason would there be that 4 tracks won't show up? Is my machine just plain broken or is there a setting out of place? thanks for your help.
as far as I remember the thing on those units there was a way to set the recording type so you might be in the setting for stereo 2 track recording.
I don't have the manual handy but that should be it -- look into the recording part of the manual or check to see it isn't in "rehearsal mode" - some of those had an option to play back a regular minidisk so you can play on top of that.
Good luck!
