Real Audio files (.ram) to MD?
DWest
Just select your audio cards output to be "Wav" or "Mixer" and then you can hookup any external audio source to the line out of your PC.
Depending on your soundcard you'd get variable results.
I used to get Real Audio files when I subscribed to Emusic - what you could do is use Real One player and burn CDs directly within it so you might want to look into that option if you're downloading the files and it is not real time streaming.
You can also record your real time stream onto your PC and transfer it later -- you just have to pick the right source in the Control Panel, Sounds and Audio Devices, Audio, Recording. With a bit of trial and error you'd get it.
  • 3 weeks later...
