from md to mac
chenners
none other than your fine recommendation of the iMic, A440.
had to go under the apple menu -> control panel -> sound -> click on the input tab -> select usb connection ->configure the input level and wa-la! (all this is covered in the iMic manual also).
then i "recorded" the live music with macromedia's soundedit. while i've got music, i'm a bit fussy about the quality of the music that i've captured. still working on that one...
much thanks.
