mz-r500 problems (with operator)
nicet
I recently aquired a sony mz-r500 from ebay for quite cheap. I knew it had playing problems (which is why it was $25). I used it a couple of days. It would play several tracks all the way through, then stop and freeze in the middle of random spots of random tracks. I would take out the battery and put it back in and it would work for a period of time and repeat the haulting. It did seem to record fine, and there were no problems with the playback other than the freezing.
I read through some things on minidisc.org including Peter's article of how to reset the mz-rxx models. My plan was to reset the system, thinking that the problem lied in the software. Now I am having a little trouble making the adjustments in manual mode.
1. One problem is that I don't have a power supply for the power adjustment, how important is this step. I will probably get a 3V wall wort at Goodwill or the like.
2. The MO Play and MO Record tests will not finish. I know my minidisc has recording on it, but both these tests keep coming up with a 032 236 NG 00 error or one like it.
3. I cannot exit the service mode. (Due to the failed tests I suspect)
I also downloaded the service manual and set a lot of the codes to the ones specified.
If you have any tips on how to put my unit in working order, I would be appreciative.
Thank you
Tyler Nice
