Sony MZ-G750 Help!!!!!!!!!!!
Dombo1981
Hi does anyone know where i could get a new radio cable for my MD
Sony MZ-G750
The connection between the unit and the cable is faulty and i really want it fixed or a new one, i dont want a knew MD as i love this one and cant really bear to part with it.
Any help would be greatly appreciated
Dominc
You could have to purchase a new remote. The only place, besides eBay, that sells this remote [RM-MZ1T], is audiocubes.
http://www.audiocubes.com/product_info.php...products_id=204
Unfortunately, they charge more than what this unit would go for new on eBay. Your best bet is to scout eBay for this remote and/or low-priced MZ-G750 auctions.
p.s. Welcome to the forums. :happy:
You might be able to get a replacement remote from Sony parts, but they won't be cheap:
Sony National Parts Center
8281 NW 107th Terrace
P.O. Box 20407
Kansas City, MO 64153
(800) 488-SONY / 7669
(816) 891-7550
http://servicesales.sel.sony.com/web/index.jsp
I've seen the G750's go for as little as $100 on eBay from time-to-time. I gotta say, though, the radio on this thing sucks. It's amazing to me that they haven't figured out a way to put an FM tuner inside an MD recorder; I wonder if the theories about radio signals interfering with MD circuitry (or vice versa) are true?
Indeed, MWielage. Case and point, Aiwa was set to release a "streetstyle" headphone-type device which had flash memory and a built in AM/FM tuner. They had to eliminate the tuner because it was causing interference with the electronics. Whilst the internals of such a device and a MD player are quite different, the characteristics that would cause interference are the same.
