audio conversion question...AAC > MP3?
Androidus
Just wanted to chime in here.
It's actually better if you go AAC -> .wav, and not AAC -> MP3. By going with the latter, you are decoding the AAC file to .wav, then having iTunes recompress it into an MP3. Then, transfering it to your unit using m3u2sb decompresses the new MP3 into .wav, then Simple Burner compresses that with ATRAC3 [LP2/LP4].
Bad. You lose a lot of sound quality.
If you own the original CD, it would be a lot better if you just directly copied CD -> MD using Simple Burner. Then again, if all you have are AAC files, use iTunes to convert it to a .wav file.
And then, there's the problem if you bought the file from the iTunes Music Store. Heh.
