SS2 - iceeedtea's build - does it support other Sony devices
DomConway
Good work on creating this version iceeedtea - I'll be downloading it later to use with my MZ-N1. I'm wondering if it'll work on my girlfriend's NWMS70D too, or will it only work for MD products? We normally use SS1 to copy music over to the NWMS70D but it'd be top if we could use your version for this too.
Welcome to MDCF. I've seen you posting over on T-Station [that is you, right?] before. :smile:
I'm willing to bet that the NWMS70D works with SonicStage 2.0. I'm poking at the registry entries for SonicStage, and I'm seeing something for the NW-MS90D. In addition, I'm also looking at the original, un-packaged-up installer directories, and I see MS70DUSB.cat and MS70DUSB.ini.
So, I'm 90% sure it should work. If it doesn't, just grab the original installer disc for the device, and install the drivers only.
SonicStage was designed to work with all Sony OpenMG-compatible products, so, that's my reasoning for why it works. :smile:
Good luck.
